Need help !!!
Go to solution Solved by STRMfrmXMN,
2 minutes ago, VideoRusher said:
finally ....... thanx you all ................ oh one more question... my graphic card has no external power supply... so how only it can get burned ?
but im definitly change my PSU as soon as possible...
The PSU can provide patches of iffy power while powering your system and thus starve your GPU of power very briefly while it's under enough load to damage the card.
my current msi gtx 750ti is went down 2 times within 8 months i got 2 brand new cards for replace but somehow its broken now. is it a manufacture problem or mine?
and i hope to get 960 as my replace i have to pay a bit for it. or should i get r9 270x ? for both gaming and editing purpose. special for video editing.
https://linustechtips.com/topic/587138-need-help/
1 minute ago, VideoRusher said:
no display..............
does it occur under load, during boot, or during idle?
no display as in no signal to your monitor? or the monitor receives signal but is blank
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/587138-need-help/#findComment-7648802
2 minutes ago, Moonzy said:
what do you mean broken? can you elaborate it?
blue screen? shut down? or something else?
also, whats the full rig spec? psu especially
i7 6700
msi h170 gamer pro mobo
16gb corsiar valueselect ram
Armageddon 500 voltron 80+ gold
2tb WD Black
1tb WD Black
https://linustechtips.com/topic/587138-need-help/#findComment-7648807
its not even posting............ in previous day its worked perfectly but when i turned on in morning its not posting... so i open my side pannel and the only thing i saw is its spinning only one fan... pcb of the card is super clear...
https://linustechtips.com/topic/587138-need-help/#findComment-7648813
try booting with only 1 stick of ram in the second slot away from the motherboard
https://linustechtips.com/topic/587138-need-help/#findComment-7648821
im already sent it for RMA cuz i tried every possible ways to power it up........... they will sent me another new 750ti  .... but the thing is, is it possible to broke 2 new gpus 4moths per one?
https://linustechtips.com/topic/587138-need-help/#findComment-7648842
yes, depending on whats powering your system (the psu especially)
armageddon makes good peripherals (headset, keyboard and mouse, i can vouch for them)
but their psu is... not that great
or it could also be ram issue, ive seen skylake being quite picky with ram. so there's that
https://linustechtips.com/topic/587138-need-help/#findComment-7648859
ram course to broke my gpus? .... they went down in different ways. first one got no disply and its one transistor burnt. now my pcb is super clean and spinning only one fan, no disply...
https://linustechtips.com/topic/587138-need-help/#findComment-7648889
18 minutes ago, VideoRusher said:
i7 6700
2tb WD Black
1tb WD Black
That terrible PSU is killing the cards
https://linustechtips.com/topic/587138-need-help/#findComment-7648894
ram wont break the gpu, but it might cause the system to not turn on since skylake might refuse to work with it
but if you say its a burnt transistor, it probably is the bad PSU causing all these
https://linustechtips.com/topic/587138-need-help/#findComment-7648903
Considering that PSU is bloody terrible I doubt it could be anything else.
https://linustechtips.com/topic/587138-need-help/#findComment-7648909
Just now, VideoRusher said:
wow thanx is fsp auram 500 80+ gold is good?
Go for a SeaSonic M12II EVO 520W if you want guaranteed quality
https://linustechtips.com/topic/587138-need-help/#findComment-7649058
I completely agree with going for the M12II, but should also note: If it's the aurum xilencer 500w 80+ gold, then it is quite good.
https://linustechtips.com/topic/587138-need-help/#findComment-7649069
