So,I've got a total budget of around 1,500 Euros.
Can you guys help me set up a build,Themed black. (Something out of a spy movie or something,very sleek)
(On pcpartspicker)
One thing though,I need the parts to be available on these websites :: ultramalta.com,http://www.bitsandbytesmalta.com/,http://www.scanmalta.com/scanshop/,http://atoz.com.mt/
I need this to easily run any game i throw at it at 60FPS High Quality..
I'm specifically using this for gaming and Work porpouses. - (So please dont get any Designs on the case or something like that)
Thanks,
iLegitus.
https://linustechtips.com/topic/587096-help-me-create-a-build/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (€304.29 @ Amazon Deutschland)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€32.77 @ Amazon Deutschland)
Motherboard: Asus Z170-P ATX LGA1151 Motherboard  (€115.89 @ Amazon Deutschland)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (€72.89 @ Amazon Deutschland)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (€90.03 @ Mindfactory)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€54.21 @ Mindfactory)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Video Card  (€643.88 @ Mindfactory)
Case: NZXT S340 (Black) ATX Mid Tower Case  (€80.89 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (€72.74 @ Amazon Deutschland)
Total: €1467.59
Generated by PCPartPicker 2016-04-25 15:50 CEST+0200
https://linustechtips.com/topic/587096-help-me-create-a-build/#findComment-7648318
1 hour ago, iLegitus said:
What's your display set up? Is it just a single 1080p 60hz display?
https://linustechtips.com/topic/587096-help-me-create-a-build/#findComment-7648730
48 minutes ago, iLegitus said:
Yes
Then you should seriously upgrade your display over buying a high end GPU that will be wasted on that display
1440p 144hz Free-sync, though it's only TN, the IPS ones on the german part picker at least are costly and the acer one wasn't on there
Here's a parts list idea anyways, the RAM/GPU/CASE can be had for less, as the list is from the US
PCPartPicker part list: http://de.pcpartpicker.com/p/hPzjYJ
Price breakdown by merchant: http://de.pcpartpicker.com/p/hPzjYJ/by_merchant/
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  (€70.22 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  (€69.87 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.99 @ Amazon Deutschland)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  (€347.84 @ Mindfactory)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  (€50.26 @ Mindfactory)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  (€74.36 @ Amazon Deutschland)
Monitor: Acer XG270HU 144Hz 27.0" Monitor  (€463.99 @ Amazon Deutschland)
Total: €1431.82
Generated by PCPartPicker 2016-04-26 07:42 CEST+0200
https://linustechtips.com/topic/587096-help-me-create-a-build/#findComment-7652474
