I'm almost certain it will, but I need to double check.
Also, Don't tell me that "this will bottleneck" or "not enough ram" ect.
Here's the list:
Motherboard: Gigabyte GA-H55M-D2H
Cpu : Intel Core i5 750
Ram: 8gb Crucial Ballistix Sport
Gpu : Gainward Phantom 4gb Gtx 760
Cooling : Artic Cooling Alpine 11 Gt
Psu : Corsair Vs450
Wifi : Generic Pci Thing
Storage: Wd Caviar Blue 1tb
Case: Zalman Zm-T4
Thanks :D
https://linustechtips.com/topic/587088-will-this-build-work/
Yeah it'll work. You can go to pcpartpicker.com to check compatibility.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/587088-will-this-build-work/#findComment-7648259
Pcpartpicker isn't always right.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/587088-will-this-build-work/#findComment-7648263
it will work, no worries. but that psu isn't good though.
https://linustechtips.com/topic/587088-will-this-build-work/#findComment-7648288
