extendors, if you get decent quality ones, are electrically not different from traces on your motherboard, hence (as long as they dont get too long offcourse) they dont change anything performance wise.
that said, i REALLY want to press on the "as long as they arent too long" thing. look at linus' pc build on the underside of a desk for the reason why.
https://linustechtips.com/topic/587064-wall-mounted-pc/#findComment-7648037
Can you post some pics of what you already have?
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/587064-wall-mounted-pc/#findComment-7648040
I"m afraid i don't have any pics but i have have a 970 on ga-z97x board if you asking for that. As you can see this guys just put some block under gpu but I personally think this does not look good however I cant think of any other better way to support gpu.
P.S I want to put my motherboard 180 degree so the cables would come out from the bottom not from the left side
https://linustechtips.com/topic/587064-wall-mounted-pc/#findComment-7648071
2 hours ago, deadric said:
Hello, I want to wall mount my pc but i got into trouble while planing installation of my gpu i don't want to use extendors because i herd it can create fps problems while gaming. So my problem is that i have no idea how to suport my gpu from simply falling off
Just cut down and old case and save the back, top, and the side with the IO
https://linustechtips.com/topic/587064-wall-mounted-pc/#findComment-7648761
