So i have only one game installed from Steam "Skyrim" i got myself a new HDD. and I installed Skyrim on that new HDD, since i'll be never again using my old HDD i wanted to move Steam file to my new HDD. Done that, and when i tried to start skyrim it said it couldn't locate Steam... :(
I really don't want to redownload skyrim reinstall all mods my net sucks..
https://linustechtips.com/topic/587038-weird-problem-with-steam/
Just like @JaredM54 said, you cannot just move the files back after reinstalling steam. If you want to backup the games before doing whatever, you MUST use steam's backup/restore feature.
Unless you boot back on your old drive and backup skyrim the proper way, you'll have to redownload everything
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7647735
so now that means i have to redownload skyrim?
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7647740
if you don't want to boot back on the old drive, yes.
fuck... boot back? old drive? wot?
drive is still there i didn't remove it.. i just moved Steam file fuck it, i'll just redownload fucking skyrim and be happy..
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7647749
19 minutes ago, lovingGamer said:
fock~ i already deleted skyrim folder :(
ah all you had to do was tell steam where your new library was and it would have just found the old files
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7648060
1 hour ago, JaredM54 said:
Did you also reinstall Steam itself? You can't move just the game files.
You are both wrong, you can move steam files wherever you want, you just have to make a new steam library folder, put the game in there (wherever you want) and point steam at it in settings, you can have as many steam library folders in as many places as you want and move them around wherever
When you "install/download" the game, Steam will see the files already exist and check them and then you can play
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7648068
Strange then, I tried it a few month ago with GTA V and he wouldn't see the games at all. even though he was downloading to the exact same folder where the files were
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7648074
you have to make the steam library into an empty folder first, then add the files in, you cant do it after
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7648078
11 hours ago, JaredM54 said:
That's what I meant, that you can't move just the game files.
What? Thats the most unclear answer you can give. Because all files CAN be moved. They just need some fiddlingbefore they work properly.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7652499
You can have the game folders in a folder then add that folder to Steam.
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7656461
I've seen some people posting here about issues with that. Might be just Steam bug.
https://linustechtips.com/topic/587038-weird-problem-with-steam/#findComment-7658009
