Graphic Issues Help Please!
Go to solution Solved by Spoderman!!,
29 minutes ago, epiccgaming said:
it is already enabled thanks for trying to help
This might be a little late but try do it the other way around (Just went opened Minecraft and saw i had the same thing xD)
I have the newest drivers on my graphics card and everything.
All screenshots are 1080 p max settings and its in more games than these two i'm showing.
This started happening when put together my new gaming pc build from scratch.
I have done tons of searching for answers but no luck i'm hoping one of you intelligent people could help me out.
Thanks
Specs:
GTX 970 4GB
i7 4790k
16GB DDR3 ram
Runs on Windows 7 professional 64 bit2016-04-24_19.17.08.png20160424193635_1.jpg20160424193602_1.jpg
https://linustechtips.com/topic/586893-graphic-issues-help-please/
Did you use any used parts in your build?
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
Thanks
Specs:
GTX 970 4GB
i7 4790k
16GB DDR3 ram
Try go to the Nvidia control panel and change the image setting from Let the 3D application decide to Use the advanced 3D image settings.
Hope this helps :)
