Using toothpaste as thermal compound
So my temps kept going up for about a week (I check My Temps every day)So i went and turned the house 2 degrees down and it was still getting worse usually its 70-80F  (21C-26c) but it went all the way up to 125F+  (51C) so i took my cooler off to find my thermal compound that came with the cooler was like cement and it was to late to go to the store and im also super cheap so i thought i would try tooth paste and it worked like a charm my tems are as low as they've ever been unless something happens i dont think im going to change it.
        --LOL
I  have GameServer`s And VOIP servers the only price is that you have fun on them.
https://linustechtips.com/topic/58678-using-toothpaste-as-thermal-compound/
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
Toothpaste likely won't last long.
Don't use toothpaste if you have a aluminium base, and be really careful cleaning it, cause toothpaste contains a very little ammount of acid that can destroy your cold plate.
Other than that, it should be fine... but it's like using vodka instead of perfume.
