I have a probelm
i have a amd fx 4100 not OC running with the normal stock cooler
when i am playing lol the cores stay around 65 - 70 degrees and i dont thnik this is good
so i was woundering if maybe i could set the base clock a little down so it cant reach the max GHz
by the way a have a biostar a960g+ motherboard
I am sorry for my english i am from germany and that is what i learnd in school:D
i would be happy if you could help me
https://linustechtips.com/topic/586511-cpu-to-hot-maybe-base-clock-down/
65-70 is abit on the high side, but it is still somewhat okay to run it at those temps
downclocking that cpu is something i wouldnt do, because why would you buy something, then make it run weaker?
just buy a better cooler
There is no such thing as a bad PC, there are only BETTER PCs
24 minutes ago, IExPeNschI said:
I have a probelm
First of all the AMD chips run HOT! My 6300 was hitting 90+ degrees whilst gaming, secondly the on-board thermometers are not the best so I would go out and get a Hyper 212 and your temps will half and it will be so much quieter! :)
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
90c lol was that pc literally on fire or what? That's a pretty high temp considering the FX 6300 shuts off at 80c. Nonetheless AMD chips prefer to be much cooler than their Intel counterpart, in my opinion hitting 65c occasionally will not hurt the chip, but anything 70c or over is simply too high for an AMD cpu. Overdrives max temp is 70c as well, they are supposed to throttle themseleves when over that temp.
No but CPU cooler (stock) was hitting 7,500 RPM!
On 24.4.2016 at 1:37 PM, Alexokan said:
You guys realize that the safe thermal limit is 61c?
All of you are degrading the life of the chip.
And AMD runs cooler than Intel.
That's BS. Ive got an FX 4300, running since it hit the market until a half year ago, still working. Was running 4.6 GHZ on ~75 degrees on full load. And i highly doubt, that your cyorig can hold ur fx under that 61c on that overclock. My current fx 6300 is running his stable 4.5 ghz since i bought him, no signs of damaging. Load temp is about 65-70 degrees.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
I run mine at 4.2 GHz and never top 55c with the Hyper 212!
Yes I could go higer, but my board would catch alight and my house would burn down!
NEVER BUY A CHEAP MOTHERBOARD! LIKE EVER!
On 4/24/2016 at 0:00 PM, IExPeNschI said:
Coolermaster Hyper 212 and i am fine?
Thanks for the fast answers
YEP :) Hope all goes well !
except. It isn't bullshit.
Looks like the 6300 is 70.5C, but the 6350 is 61C. Most FX CPU's will list 61C as the safe thermal limit.
Right off AMD's site: http://products.amd.com/en-us/search/CPU/AMD-FX-Series/AMD-FX-8-Core-Black-Edition/FX-8350-with-Wraith-cooler/141
Oh, and it does. Synthetic load will breach that limit by a couple of C, but under gaming I sit under it.
Why would amd give u an stock cooler, which breaks that limit by far then? Going higher then this "safe limit" wont do anything.
The stock cooler will not break that limit under normal load, also why do you think that AMD overdrive shows max temp as 70c, you do realize that is the thermal throttle temp on the FX line right? Go ahead and hit 80c and see what happens ( surprise thermal shutdown.) But I guess AMD wouldn't know their cpus max safe operating temps according to this guy, they must simply be that incompetent, that's why single core performance must be so shit too.
I love when people get all pissy about factual information just because they don't like what it is.
My PC will freeze or blue screen if I hit upwards of 65c for more than a very limited time frame. I have heard of people running these chips hot and not having that problem, at the same time.
Advice: Just do you. If it works for you, great. But, you cannot deny what AMD specifically says or recommend otherwise. People should be trying to keep their FX CPU's in the documented and tested thermal levels provided by AMD. If you don't, you are assuming the risk of CPU degradation or complete failure.
Im not denying that fact, amd says it is the recommend temperature. Im denying the fact, that it will reduce everys cpus lifespan. U cant say that that easily.
On 4/24/2016 at 5:23 AM, IExPeNschI said:
I have a probelm
Guten tag c:
it would be best you were to get a new cooler, the stock cooler is pretty bad. you'll see a huge difference in temps and it will probably run way quieter, i got a h60i for my fx-8350 and went from 20-30C on idle to 9-11C. I won't recommend the h60i because i don't know your budget, i've heard the 212 evo is pretty good though! (also your english wasn't bad at all, just saying.)
