Look at my specs below, I have a similar CPU to yours and I get about 100 FPS average. I have everything on low or off except Shadows and the two Anti Aliasing settings.
CS:GO loves a strong single core because when I turn Multicore Rendering on or off, it does not make a (or much) difference. I have it off because it creates some input lag. But that does not mean the GPU isn't important also.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/586450-csgo-help/#findComment-7642323
21 minutes ago, Mandeep said:
If i buy cs:go through steam, How much gb i have to download to play?
I am asking about downloading size not installed size.
Is it play able on intel i3 2100?
I have a laptop with a i3 3110m, notice the m for mobile so its a bit weaker. And intel hd 4000 graphics. I run everything on low and it never goes below 30 fps. You should be fine.
https://linustechtips.com/topic/586450-csgo-help/#findComment-7642329
