Hi,
So, my video card driver would tend to crash here and there but not often. Then one day I updated my driver then now all the time my PC kept crashing. I even got BSOD. So eventually I decided to reinstall windows. Everything was working fine. I installed latest drivers no problem. Then once I opened up hearthstone I could see tears on my screen, weird colours then it just crashed and couldn't fix it. I'm resetting my PC now. Is it my video card or SSD? It's getting frustrating. Good thing I backed up my stuff. I would appreciate the help. Thanks.
Specs:
GT660TI
3770k
Sabertooth z77
16gb RAM
364.72 driver
Windows 10Pro
https://linustechtips.com/topic/586042-computer-keeps-crashing-help-please/
26 minutes ago, twod said:
Hi,
Specs:
GT660TI
3770k
Sabertooth z77
16gb RAM
364.72 driver
Windows 10Pro
What does event viewer say?
I'd advise a clean install of Windows.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
I've cleaned installed once and same thing happened. I just reinstalled a third time and well I haven't bothered to install the driver
It is 100% driver related.  You need to make sure you're installing Windows correctly.
