So for some reason the internet on my pc is extremely slow a i took a speedtest these are the results http://www.speedtest.net/my-result/2982904543
my internet speeds on everything else is fine like my phone and none such i've the general stuff your supposed to do virus scan, reset router etc please help i can barely load a youtube video at 360p
Thanks moose
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/
Do you use WiFi? maybe it the WiFi receiver on your PC
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793295
Ethernet all the way son but i have a 10FT ribbon ethernet cable running to my router
Edit: love your profile pic btw
Maybe it is your mobo what mobo do you have?
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793337
Try switching the cable, it may be broken.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793338
old msi 770-c45 cant even be bought anywhere
Well i can buy it :P http://azerty.nl/8-1126-217782/msi-770-c45-moederbord-atx.html do you have another mobo you can try?
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793350
It's only my download speed that has suffered my upload was always that slow normally my download would be around 5mb/s
maybe your ISP is F cking with you :P
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793367
Maybe it's time for a new mobo/NIC.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793396
Don't say that im looking for a solution that doesn't cost money i don't have
lol sorry  :P
https://linustechtips.com/topic/58601-help-slow-speeds-on-pc/#findComment-793403
