2 minutes ago, Fourmi Kill3r said:
Hello!
Ok so here is the problem:
  Reveal hidden contents
Anyone have a trick to stop the cable doing this constantly?
Stop rotating your headphones?
Spin your headphones whichever way until the cable no longer bunches up, then be very careful to not ever rotate it?
Sig under construction.
https://linustechtips.com/topic/585423-headphones-cable/#findComment-7632780
I never rotate them
What i want is like... something i can put around the cable to stop this
https://linustechtips.com/topic/585423-headphones-cable/#findComment-7632786
1 minute ago, Fourmi Kill3r said:
I never rotate them
Okay.
For something you could put around the cable, I'd suggest maybe some twisty ties that you can use to bunch up all the unnecessary cable in a friendly way, so that there is only the necessary amount plus a small amount?
https://linustechtips.com/topic/585423-headphones-cable/#findComment-7632800
get headphones that don't have a crap cable?
I would actually stretch it out straight, and lay it in the sun. The heat might help to 'iron' the cable out a bit, so that it will stay straight.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/585423-headphones-cable/#findComment-7633191
