Hi,
well I have got a new problem with my pc build. First I had this problem that i couldn't install windows because the mouse and keyboard would shut down when I got into the installation. Well this was fix by setting windows 7 installation to enable in bios. HAHA that was a bit embarrassing! - well now I have a new problem; I succeded the installation of windows, and was installing new drivers from the cd that followed with the motherboard. WELL, I got to the point where it was going to update BIOS, and it said that when it was going to reboot, mouse and keyboard would be locked. Now after it was rebooting the motherboard turned on the light that says CPU fail!! - so now I can't boot AND there is no longer a signal on the screen. How do I fix this?!?!?
I hope this is understandable, i'm from Denmark, so sorry for the bad english :)
https://linustechtips.com/topic/585376-cpu-fail-help/
Try reseating the CPU power cable.
Theory is when you know everything but nothing works. Practice is when everything works but you dont know why. In this computer, theory and practice are combined: Nothing works and i dont know why.
Atleast i can manage Some things, like my current OC personal best.
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632385
try reseating the power for the CPU, both the 24pin and 4 or whatever pin one, if that fails try re seating your CPU
Builds:
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632392
Highly stupid question (but in some cases new pc builders may forget): Did you mount a cooler on it, and does it have thermal paste?
(cant be too sure, you know)
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632404
I have done that. reseating both the cables and the CPU. I've even tried to pull one hardware at a time out of the system, to try getting other systemfails. Nothing that helps...
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632406
is there a backup BIOS that you can switch to on your motherboard?
Builds:
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632412
HAHA, there are no stupid questions, only stupid answers ;) - but yes, I have a Corsait H80i watercooler mounted, with paste. So that's not the problem.
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632417
Aaaand did you remember to plug in the pump?
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632424
No, there are pins, that you can mount a cap on, or you can unmount the battery,but that dossen't help anything :/
Ok what are the specs?
Builds:
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632429
Just now, klg1992 said:
yeah, everything is build correct, I'll se if i can take a picture!
And assuming the pump works fine...
You might have gotten a faulty cpu. Try getting it exchanged.
If you can, try a different cpu in the socket.
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632441
How far into the "bios update" did it get? Because that might have bricked the motherboard.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632452
All I could see was a black screen. You know; It rebooted as if you woud restart the computer, but there is only black screen. I guess you're right about that the motherboard is bricked!
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632460
I don't have another CPU unfortunately, but everything worked as it should untill the bios update, so I don't asume that the CPU destroyes all of a sudden like that? :)
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632473
I would contact MSI support. I'm not familiarly with recovery. There may a feature with that MSI board that allows to fix this, but I'm not sure.
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632476
yeah, I'll have to try that, it's so sad, I was really looking forward to play on a new pc build :D
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632484
Probably worth asking on here or looking on the web for more helpful resources.
https://linustechtips.com/topic/585376-cpu-fail-help/#findComment-7632495
