Looks like a nice build and the picture looks ok but it would have been nice to see more pictures, Also if you can you should add more info about it like what z77 motherboard is it for example.  =P
Ok its a realy old and crappy mb but i i'll buy a Sabertooth soon. :)
https://linustechtips.com/topic/58528-my-first-build/#findComment-792832
Very nice specs for a first build! Well very nice specs for any build actually :P
So you bought a k-series CPU, you know what you have to do now... Overclock that baby! It would be blasphemy if you didn't ;)
Ofcourse I want more pics and I would also be interested in some benchmark results!
Quick system specs: MotherboardAsus P5Q-PRO CPUIntel Q9550 @ 3.7 ghz GPUEVGA Geforce GTX 570 HD superclocked RAM6 gigs of ddr2-800 (ouch) DrivesSeagate 320 GB drive for windows and some apps, Seagate 1000 GB drive for games and documents OS: Windows 7 Ultimate 64-bit If you think its bad... it runs crysis 3 (almost) maxed out: youtu.be/dL3PNorbub8
Project [bBB]: This is a clickable link
https://linustechtips.com/topic/58528-my-first-build/#findComment-793615
Just realised I gave you my 100th post... Dayum be happy with it lol :)
https://linustechtips.com/topic/58528-my-first-build/#findComment-793632
Thanks! And i will be oc'ing after i get my h100i in some time now. :)
https://linustechtips.com/topic/58528-my-first-build/#findComment-795487
Excellent hehehe
https://linustechtips.com/topic/58528-my-first-build/#findComment-795638
