Could use some friendly help!
Go to solution Solved by EX1,
Plug a fan into that fan header and power your pump off a different header with a custom curve set in the BIOS if you want.
Asus Z170-A - I have the corsair H110i installed (water cooler) and it is plug into the water pump cpu fan header on my mother (W_PUMP) with the TPU set to Enabled (water-cooling) and I am getting this CPU Fan Speed error but all my fans are spinning (including case fans (NZXT H440) and the BIOS displays my CPU temp at 28-35 degrees, is this simply because am not using a CPU fan? or is it something more serious? and how do i get it to stop this error coming up?.
Also in the ASUS BIOS EZ MODE interface it has all my fans speed info as N/A (even though they are all spinning) so I think my motherboard isn't getting fan speed readings from any of my fans? Why? (case fans are connected to a fan splitter that comes with the NZXT H440)
Disclaimer - I'm a total noob, this is my 1st build.
https://linustechtips.com/topic/585206-could-use-some-friendly-help/
connect the cpu fan cable into the cpu fan header
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
15 minutes ago, faxon99 said:
Instead of using the CPU fan header meant for water cooling ?
They are exactly the same thing, Asus just decided to name one "PUMP" for whatever reason.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Or you could disable the "test" for the CPU fan header in the BIOS, as far as I know.
That way it will ignore that there is no CPU fan plugged in and just boot normaly.
Please quote me in any answers to my posts, so that I can read them easily and don´t forget about them. Thanks!
I love spending my time with PC tinkering, networking and server-stuff.
