Problems with new hard drive
Solved by Oshino Shinobu,
2 minutes ago, ismma99 said:
sorry i derped https://gyazo.com/31375f00898bd5572ebadc3bc52ae689 ok i found it its primary partition is this corrcet ?
It's disk 1 at the bottom. You need to right click the hashed rectangle and then select create new volume (or something similar)
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases4 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
