Quiet Liquid Cooler?
Go to solution Solved by Curufinwe_wins,
1 hour ago, HKZeroFive said:
If you're looking for quiet coolers, air cooling would be your best choice. Just saying.
Except it isn't... Unless you are running stock speed (or near stock speed)
1 hour ago, bambam47 said:
I'm talking about AIO I don't have the case for custom and quiet in general
Yea. Then if you are willing to replace stock fans, I'd consider the following:
Corsair H115, H100i V2
NZXT X61
Swiftech H220 X2, H240 X2, H320 X2
If you don't want to replace fans:
Swiftech H220 Prestige, H240 Prestige, H320 Prestige
EK Predator 240, EK Predator 360.
With all but the EK aio's the pump might end up being the loudest part.
That said I swear all of the people who bitch at them have either have never used one or straight up don't know how to properly bleed the system.
I think SPCR's FIASCO of STUPIDITY on their attempt at a quiet watercooling build is a good example of this common misconception.
http://www.silentpcreview.com/article1437-page11.html
Quiet as in quiet once you replace stock fans?
Just about all the new ones (based on newer Aseteck pumps).
Otherwise, the EK Predator and the Prestige Lineup from Swiftech come much quieter out of the box, but cost a stupid amount.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628277
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628279
NZXT X61
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628313
most silent AIO = one without fans, without radiator, without water, without pump and waterblock, just one big passive heatsink
yes im talking about passive heatsink `-`
but i guess if you insist on AIO, get something like a Kraken x61 and swap the fans and do push pull to achieve maximum silence
just make sure you have the clearance to do so
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628321
I'd like to see proof of that. Same can be said of the fans or pumps of an AIO.
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628349
2 minutes ago, bambam47 said:
Which high static pressure fans should I replace them with?
For 240mm variants with an emphasis on silence I would recommend BeQuiet's Silent Wings 2.
Alternatively, Noctua NF-F12, Vardar 120 FF2, Venturi HP-12 are all very capable fans though you will want to turn them down, esp the venturi's.
There are also some other good options I can't seem to think of (really there are a crapload of 120mm fans to choose from.)
For 280mm variants with silence in mind there are again BeQuiet Silent Wings 2 (although the 140mm version isn't quite as exceptional).
Alternatively, consider the NF-A14, Vardar 140 FF2, Venturi HP-14, Phanteks PH-F140HP.
The last fan is as far as I am aware notably the best on the market today for the 140mm cooling fans, but is normally very hard to find (I did see them listed on Newegg though.)
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628360
A: Cooling my oc'd cpu under full load isn't possible by ANY air cooler on the market today.
(EDIT: Upon reflection, my claim A isn't quite true for my 24/7 OC, even if it was for my testing OC. A D15 would have probably just made it in the high 80s at maximum fan speed. Additionally you could always strap industrial fans on quite a few of the high end air coolers and temps would probably be "functional".)
See below:
Both are from my phone's onboard mic. It has been calibrated against an professional device (so it is ACCURATE), but I can't guarantee is it as PRECISE as one. Additionally it is still early enough in the day that traffic (and all the other stupid shit you deal with living in the middle of a small city) creates a notable noise pollution background (at least by my standards), but hey you wanted proof now.
Image 1 is 1 foot from the top of my PC running Intel XTU Stress test.
Image 2 is with my pc off, and represents background noise.
Both measurements were taken over an minute. Given the nature of this device, I certainly can't tell you my exact margin of error results, but I would not call 1 dB enough to distinguish from background.
It can probably be however assumed that we are at least 21 dB while running. (I don't know if I have anything saved, but when I was configuring the system I believe I got down to 23 dB load.)
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628412
5 minutes ago, Curufinwe_wins said:
A: Cooling my cpu under full load isn't possible by ANY air cooler on the market today.
See below:
While I'll give you full props for your 'full custom loop' system being extremely quiet, I wouldn't think the same could be said of a prebuilt AIO as OP requested? To do so, you'd need set a custom fan and perhaps pump curve to rival that of an air cooler.
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628531
My x61 is sitting in a closet right now and I have no spare decent fans (I don't want to get started on how AWFUL the stock fans are at any speed) to haphazardly throw it on a pc, or I'd do that as well.
It certainly wasn't as quiet, but the pump noise (at the time) was below my pc noise threshold (which I think was ~30 dB, but it was months ago so don't quote me on it.)
I actually ran the pump at 100% speed all the time because I found (when I arbitrarily was playing around passive idling modes) it was effectively the same noise level (as close as I could tell), but had a smoother sound profile running faster than slower (perhaps due to some small air pockets I didn't get out enough.)
Either way, watercooling pumps have come a very long way in the last few years (both for AIOs and custom systems), and unless you have a very low auditory target, they are unlikely to be notable (assuming you are able to bleed them correctly) over the fans.
AIO noise is kinda a funny thing. It definitely is louder at low thermal yields (assuming you don't run passively) but at a certain threshold it simply begins to obliterate the lower heat capacity of air coolers. Where that threshold is many will disagree, but I tend to hold it at around the 150W thermal load (say a moderately overclocked Z-series chip or any X-series pc.
If you really wanted to avoid ANY concerns about pump noise (fans reduce to the same thing on high end air coolers vs aios assuming proper noise isolation on both), I did include recommendations for EK and Swiftech AIO's.
The EK predator uses a noise isolated DDC pump (the louder of the two pumps custom watercoolers generally use), which SCPR has some pretty comprehensive data on:
EK-SBAY DDC 3.2 PWM
PWM %
RPM
SPL*
100
4500
24
50
4200
22
45
3700
20
40
3250
18
35
2700
17
30
2200
16.4
25
1700
15.8
20
1280
14.7
* dBA@1m
And running at 3000 rpm is totally sufficient to get the job done (at a certain point running the thing faster actually makes things worse.) So unless your goal is sub 18 dBA at 1m that AIO pump won't concern you.
The swiftech AIO variants use a MCP30 pump which is I'll admit rather more questionable than both the newest Asetek pumps and the DDC/D5's generally used for custom systems, but when they don't fail they are well known for quiet operation.
https://linustechtips.com/topic/584999-quiet-liquid-cooler/#findComment-7628616
