I'm new here and need some assistance im trying to put together a gaming rig. I want to buy a decent graphics card when I get paid but until then I'm working with a xpc shuttle with 16gb ram and a i7-3770 at 3.4ghz that my dad gave to us for my wife's birthday. It is fairly newer. I'm working with a limited power supply but want to transfer the components to a better aftermarket case and can upgrade the power supply and then mother board later, limited budget. I don't know if I can reuse the cooler as it seems proprietary for this case. I also have two 2tb hard drives in it. I also have a donor hp desktop that has a GeForce 220, i7-950 4 two gig ram sticks, and a 1.5 tb hd. Should I use the 220 in the shuttle for now or is the onboard graphics going to be better? Also looking for ideas on what to do with these two systems as far as cases I could use and parts to upgrade and in what order I should do so. I'd like to have a gaming rig and use the other system for storage/media. I added some pictures for reference. The first power supply is the one in the hp and last is the small powersupply in the shuttle. Thanks for any input.
https://linustechtips.com/topic/584984-help-newbie-upgrading/
I dont think you can reuse that cooler
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/584984-help-newbie-upgrading/#findComment-7628204
18 minutes ago, bdub109 said:
So you need to upgrade your PSU and GPU?
here are some decent options, also the 380 4GB card will be perfect for 1080p gaming
also a decent case recommendation in there I guess.
PCPartPicker part list: http://pcpartpicker.com/p/BNrLWZ
Price breakdown by merchant: http://pcpartpicker.com/p/BNrLWZ/by_merchant/
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($189.99 @ Newegg)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($40.98 @ Newegg)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $634.70
Generated by PCPartPicker 2016-04-20 22:07 EDT-0400
https://linustechtips.com/topic/584984-help-newbie-upgrading/#findComment-7628253
I would like to upgrade the gpu then case and powersupply and cooler. I'm working with two systems currently. I want to do the gaming rig then a media/storage build. I was thinking a gpu around the around 100-200 for now. I don't know how limited the motherboard is as far as options for upgrading down the road and what case it would fit into. So I think I will have to upgrade the motherboard too. The only thing i will keep long term in the gaming rig is probably the cpu, ram, and hdds.
https://linustechtips.com/topic/584984-help-newbie-upgrading/#findComment-7628346
