I just got home, logged onto my computer which I installed Ubuntu on last night, and when I tried to login it froze for a while. I had to replug in my keyboard but after about 30 seconds it was fine. Then when I got into my desktop there was no sidebar, overbar, or anything not on my desktop. Please help!!!
Tried restarting and same thing happened.
specs are:
  • i7-5820K
  • 32 GBs of DDR4 memory at 2133
  • MSI Godlike Gaming X99A
  • PNY GTX 770 Signature Edition
  • Samsung 950 Pro 256 GB version
ubuntu 14.04 LTS
K95 RGB with Cherry MX Brown
Noopoo Nano keyboard (secondary because I thought that the K95 was the problem)
Mionix Naos 7000
Acer 25" 2k monitor.
https://linustechtips.com/topic/584940-ubuntu-problems/
Specs?
Computer age?
Did restarting fix it?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7627750
linux is an interesting operating system to say the least ^_^
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7627754
Sounds like just a glitch
You can try to upgrade and update to repair any broken programs or drivers etc
sudo apt-get upgrade
sudo apt-get update
sudo shutdown -r now
if that doesn't work, try a reinstall maybe a new iso
If that all fails it may be a driver issue to look into or a gui issue which can be replaced
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7627822
sudo apt-get update
I would do that but I can't even get into command line.
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7628017
Can you not right click? eh thats not good but only a bump
By default SSH should be available, you can use your phone or PuTTY on windows
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7628047
No right click. I don't think SSH would help. When I do right click it only lets me make another folder, change my background, etc.
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7628094
ssh is just a remote terminal, so you can then run the update and restart commands, and if needed other fixes
It really seems to just be a glitch in the UI, I've had it happen on mint but restarting fixed it. So the only real options are SSH, a new install, or try to get to the settings/terminal from your file system(home)
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/584940-ubuntu-problems/#findComment-7628123
  • 2 weeks later...
