I saw this system for sale and it seems like a decent build for my sister (shye mainly plays minecraft but wants to play some GTA 4 now too). How much do you think it would be worth?
Specs:
CPU: Intel Core i7 - 2.67GHz (920?)
Cooler: Scythe mugen 2 cooler
MoBo: Gigabyte GA-EX58-UD5
GPU: 2x MSI Geforce GTX 580 TWIN FROZEN II SLI geschakeld
RAM: Kingston HyperX DDR3 6gb
PSU: Corsair HX850 Professional series GOLD
Case: Lian Li PC-A77B
Optiarc DVD RW
Western Digital VelociRaptor 1 TB HDD
USB Fan & Thermometer controller
Lian Li Cardreader
https://linustechtips.com/topic/584753-buying-a-system/
$400 maybe $500
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7625691
Specs:
  Reveal hidden contents
Optiarc DVD RW
Lian Li Cardreader
all these components cost $1400 approx ,also it is pre build so price could be more
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7625873
1 hour ago, houtekamert said:
Well how much are you willing to spend? As for like 500 bucks it's better just to build something new most likely unless you get that one really cheap.
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7625895
Probably not in 2016 man, maybe canadian or AUS bucks
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7625898
34 minutes ago, Aditya0002 said:
I have Checked out prices for all the parts on Google in USD
The only thing still worth anything major would be the case, as it's a standard pretty overpriced Lian Li case, otherwise the CPU is passable but old, and the GPUs are really old.
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7631613
The seller wants €450, so i guess it's not really worth it then?
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7634014
@houtekamert
i know that this pc is having generations old pc hardware and NO ONE will recommend buying that pc , -_-
i mean really ,who will buy sli of gtx 580 in 2016 i7 920 BLOOMFIELD in time of skylake that i7 920 is having worst value for money of all cpu available for now ,over all it will be a really senseless  to buy this pc
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7634181
see if he can let go for around 350, this pc should still give you decent fps in medium-high settings, provided the gtx 580 aren't 1.5gb ones.
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7634245
Maybe at 200 if that
https://linustechtips.com/topic/584753-buying-a-system/#findComment-7647015
