I just bought 2 Xeon E5450 CPU's to use in 2 LGA775 motherboards I have, but I've ran into some issues.
On a Gigabyte GA-P35-DS4 mobo would detect the CPU correctly in the bios but windows didn't start. Giving me a blue screen with a different error each time. Memtest finds 65000+ errors with the Xeon chip, but no errors with a Q6600.
On a MSI P35 Neo board I had a litte more succes, the Xeon was detected correctly and was stable in Windows, so I started overclocking. At one point I hit the limit (close to 4GHz) and I had to reset CMOS. After that the default FSB setting was 266MHz, instead of the 'real' 333MHz. It is still stable at its 'real default' 3GHz, 333MHz FSB, but I can't overclock beyond 3.2GHz while 3.8GHz was stable before the CMOS reset. Also, the default FSB/DRAM frequency ratio is set at 1:1.5 instead of 1:1. I cannot set it to 1:1 manually, 1:1.25 is the lowest value.
Both motherboards have the latest BIOS installed. Do I need to update the microcodes? I know very little about this, so I'm a bit apprehensive to do it.
https://linustechtips.com/topic/584692-771-to-775-problems/
