Im new to pc building and want advice on parts, keep in mind i don't plan on overcloking and are using a 1080p display. Graphics card probably isn't better than any 4gb vram card but its only 20 dollars more and i picked because i dont want to mess with the pc to much after its built for a year or 2. Im using a SSD and an HDD but im not sure and what i should write on the SSD. Thanks a lot for the help
http://pcpartpicker.com/user/Roblesjose409/saved/RqhWGX
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($233.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($149.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($74.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($86.79 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($322.99 @ SuperBiiz)
Case: Corsair SPEC-02 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($74.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($14.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($85.49 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($24.99 @ Newegg)
Total: $1219.59
https://linustechtips.com/topic/584327-first-pc-build/
Just now, DuckingNameTaken said:
looks quite good. if you want to go very hard on the overclock you will need a better cooler though.
this is what i would do do at this price point:
PCPartPicker part list: http://pcpartpicker.com/p/Vtp8RB
Price breakdown by merchant: http://pcpartpicker.com/p/Vtp8RB/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($307.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.44 @ OutletPC)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($94.99 @ Amazon)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($73.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($104.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  ($429.99 @ Newegg)
Case: Fractal Design Core 2500 ATX Mid Tower Case  ($44.99 @ NCIX US)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($61.98 @ Newegg)
Total: $1189.25
Generated by PCPartPicker 2016-04-19 15:04 EDT-0400
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621598
Total: $1219.59
You said you don't plan on overclocking, but you pick overclocking grade parts? o.O
Here is the fixed part list, without the overclocking grade parts:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.99 @ Newegg)
Total: $1063.79
Generated by PCPartPicker 2016-04-19 15:33 EDT-0400
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621695
6 minutes ago, Shahnewaz said:
that motherboard has really bad IO and is to small for the case so its going to look weird. also dont go with evga psu's
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621739
What do you mean "really bad IO"?
I couldn't care less about looks. If OP wants, he can pick an ATX motherboard. In that case, there's this: http://pcpartpicker.com/part/gigabyte-motherboard-gaz170hd3
Still significantly cheaper than his choice.
What's wrong with that PSU? It ranks the highest in the PSU Tier list (tier 1/7).
Quote
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621764
Just now, Shahnewaz said:
its not a top priority on a mobo but there are people that have more attached to their pc than keyboard and mouse. and then it becomes an issue. i use 9 usb ports without even mentioning usb sticks.
of course z170 makes no sense.
it may be a high end one but evga is known for low quality capacitors. i didnt believe it myself at first too but the psu guys have a pretty strong opinion on this
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621805
If that is the case with OP, then he/she should let me know. I don't recommend parts based on assumptions.
Like? I'm all in for a correction, I definitely don't want to recommend a bad PSU, but I need words first.
Quote
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621830
looked over the comments and looks like i cant find something about the super nova lineup but to the other ones. not quite sure now maybe i got that wrong :D
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621923
Yeah, I double checked his PSU choice with various lists and reviews. Seems to get glowing recommendations all around. ;)
Quote
https://linustechtips.com/topic/584327-first-pc-build/#findComment-7621972
