Power Supply Suggestions, going modular.
I recently got a BitFenix Ghost and with my current power supply cable management has been tricky so I think it's time to go modular.
Right now I'm looking at this power supply, it's $90 after using a promo code. http://www.newegg.com/Product/Product.aspx?Item=N82E16817182263&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=6146846&SID=1n8uemv2qk4j2
Would this be enough to power two GTX 670s in SLI?
If there's something better that's below $100 any suggestion would be great. Also the promo code ends on the 3rd soa quick reply would be greatly appreciated.
OSX/WiiU/XO/PS4/PS3/N3DS
https://linustechtips.com/topic/5843-power-supply-suggestions-going-modular/
It's a fine unit, (OEM is superflower I believe), but not enough for 2x670's in sli. The TDP of the 670 is 170W, and TDP isn't necessarily max power consumption. I would venture a guess that each of those 670's could pull close to 200W under load. Add in a processor, even with a low overclock on something like a 3570k or a 3770k, which are rather power efficient processors, that's another 100-120W minimum. If you're using something like an 8350, it's more like 200-220W. Add that to the two 670's and you're pushing over 500W with just the cpu and gpu's. Add mobo chipset, vrm inefficiencies, a drive or two, and a few fans, and you're pushing 600W minimum. I would go with at least a 750W unit if not 850W.
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
