This concept of case fans has been bothering me for a long time. I need some help regarding what type of case fans I should get for my pc build.
I am getting an H75 AIO cooler from corsair, which already has two SP fans. Anyway, I am considering whether to get 3 AF Fans for my case, or 1 SP fan at the back and 2 AF fans at the front.
Help would be greatly appreciated,
Thanks a lot. :)
https://linustechtips.com/topic/583783-case-fans/
What are your specs?
Moved to Air Cooling.
https://linustechtips.com/topic/583783-case-fans/#findComment-7615815
1 minute ago, JDalli said:
i5 4690k , GTX 760 4gb
What case do you have?
https://linustechtips.com/topic/583783-case-fans/#findComment-7615954
2 minutes ago, JDalli said:
If you're asking to check if the case supports the cooler, it does.
No, but the case will affect what fans would be most appropriate and it would make it easier to help you.
https://linustechtips.com/topic/583783-case-fans/#findComment-7615974
4 minutes ago, JDalli said:
Well, my case isn't from nzxt or anyone famous, its a random case i got called  Gaming PRO-975B , cringe, yes I know.
Any bit of info can help. The case is fairly open so airflow oriented fans would be most appropriate. If your hdd cage if full, it would be good to get a fan with more sp there. If you tell us where you're shopping/located and your budget, I could give some specific fan recommendations.
https://linustechtips.com/topic/583783-case-fans/#findComment-7616007
5 minutes ago, JDalli said:
Amazon. Although if u recommend SP fans I can buy from a local store :)
In the US? What's your total budget for the fans?
What kind of fans did you have in mind from the store?
https://linustechtips.com/topic/583783-case-fans/#findComment-7616038
My experience with Corsair fans has been less than great, I'd recomend the new CM Silencio fans, but they are a bit more expensive I thought they'd be and the 1500 RPM version is not on amazon. Specter Pros, Cougar Vortex, AP123s, Phanteks MP120, there are quiet a few options that are quieter and better performing for the same or lesser price than the corsair fans.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/583783-case-fans/#findComment-7616111
http://www.amazon.co.uk/gp/product/B007RESFR2/ref=s9_simh_gw_p147_d0_i2?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=desktop-1&pf_rd_r=1SYVFM48FG3K3PDJGB9H&pf_rd_t=36701&pf_rd_p=867551787&pf_rd_i=desktop
No, not the US. I live in Malta.
https://linustechtips.com/topic/583783-case-fans/#findComment-7616449
https://linustechtips.com/topic/583783-case-fans/#findComment-7616580
