Hey guys, so my Corsair H110 is on it's last legs, and I'm in the process of trying to find a new CPU cooler for my i7-3770k (LGA 1155). I'm also trying to make the switch back from liquid to air cooling as my H110 didn't last quite as long as I'd like it to, and I've heard that air coolers tend to be more reliable. My case is a Corsair Air 540, so even some more robust coolers should fit, but I'm looking for a piece that will compliment the black and green theme of my rig. The only additional constraints I have is that it be quiet (I've gotten used to the near silence of liquid cooling =) ), and that it can fit on an ASROCK Z77 Extreme4 with two sticks of Corsair Dominator Platinum RAM installed (the heat sinks are quite tall). Any suggestions?
America: Land of the free, home of the awesome...
https://linustechtips.com/topic/583755-need-help-finding-a-cooler/
I'm using the Arctic Freezer 13. Inexpensive, very quiet (at least in my opinion) and also pretty easy to install
(for black/green theme probably the Limited Edition would fit)
Link: http://www.amazon.com/ARCTIC-Freezer-Limited-Multicompatible-installation/dp/B00449S3VQ/ref=sr_1_1?ie=UTF8&qid=1460996285&sr=8-1&keywords=arctic+freezer+13+limited
Obviously, the CoolerMaster Hyper212 Evo, but it won't be anything near the green/black color you're looking for. Apart from this, it's really cheap, silent and can cool my FX-6300 OC'd with a quite high voltage
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
There are a lot of shades of green fans on the market so it makes it difficult to match. This is also aided by the fact that the human eye can (usually) see more shades of green than any other color.
The good news is that most CPU coolers allow you to swap out your fan with something of your own choosing. I recently bought a Deepcool GAMAAXX 300 for my system and was surprised at how well it worked. They make some pretty beefy ones and all of them support fan swapping.
DEEPCOOL Gamer Storm Lucifer V2
DEEPCOOL GamerStrom ASSASSIN II
Be Quiet is a highly regarded brand that also supports fan swapping though most of their fans are usually black.
be quiet! SHADOW ROCK 2
be quiet! PURE ROCK
ENERMAX Twister
EVGA 100-FS-C201-KR (heard this kind of sucks)
CRYORIG R1 Ultimate
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
I'd recommend a phanteks tc14pe because you can mount your own fans to it, but you said you use dominator ram, which is extremely tall. Big air doesnt like big ram :D
Current rig :  |CPU: 2600K @ 4.8GHz|   |GPU: EVGA ACX GTX 980 @ 1.5GHz| |Ram: 16GB G.Skill Ripjaws X|   |Storage: Samsung 840 Pro 256GB, WD Blue 500GB, WD Black 1TB|  |Motherboard: AsRock Z68 Extreme4 Gen3|   |Cooler : Black Phanteks TC14PE (3 Corsair AF140s)|   |Power Supply : Thermaltake TPG-850M|  |Case: Phantom 410 Black|
be quiet! PURE ROCK
The type of green I'm trying to match is a bit closer to Razer green. Tentatively, I'm going with the be quiet! Dark Rock 3 because of it's looks and quiet profile, but according to another post on this forum (I'll link it below), it may not have the clearance I'm looking for. Could anyone who owns Dominator Platinum RAM share what kind of cooler they are using?
The Pure rock shouldn't give you any issues with RAM clearance as long as you are only using two sticks. It may be a little close if you are using four but I think you can mount the fan to the other side of the heatsink in a pull configuration.
Just to double check, the Dominator Platinum RAM claims it has a height of 60mm, and the Dark Rock 3 claims it only provides for 39mm. Does the Pure Rock make up for the extra space? And what are the differences between the two in addition to the Shadow Rock Slim, other than the price and color?
