Strange PC issue
Solved by sjoerd108,
Seems like some dirty programmed driver utility from acer that is ment to install drivers. It can be a backround program that is doing this try looking in the startup tab in taskmanager.
EDIT: just looked at this topic on superuser:
http://superuser.com/questions/1032020/annoying-popup-cmd-exe-findstr-cannot-find-the-path-specified
It says you should disable the startup service:
FUB_send
