My ram is pinned at almost max usage and its causing bad lag on my pc. I dont know whats causing it as nothing is using ram im not sure if somthing wrong here or if its supposed to look like this but its being rather laggy and i dont feel its right ol6VF.png
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/
Run Malwarebytes or reinstall windows.
i like linux
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608182
I ran Malwarebytes full system scan a few nights back nothing came up i can run it again. As far as windows goes being on upgraded windows 10 with out a disk how do i go about that ? Also im just double checking this ram usage is no where near correct right.
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608183
Try reinstalling the ram. i had this weird bios beep issue which caused random lag and i fixed it by reseating the ram
Alnair (Main PC):
CPU: i9-7900X with EK Supremacy RGB and SE 360 radiator
RAM: 32 GB Trident Z RGB 3000 MHz
MB: Gigabyte X299 Gaming 7
GPU: GTX 1070 Founder’s Edition
PSU: EVGA 850 G3
SSD: WD Blue M.2 1tb, Sandisk SSD Plus 1tb
Mistle (NAS):
CPU: Pentium G3258 with stock cooler
RAM: 8GB HyperX Fury DDR3 1600 MHz
MB: MSI H81M-E33
GPU: Intel integrated
PSU: 500w Cooler Master
HDD: 2 x 2tb WD Red in RAID 1
Armakarth (NAS/3D modeling station/my old computer)
CPU: i7-4790K with Hyper 212
MB: MSI Z97-G45
GPU: EVGA GT 740 SC
PSU: 750W Sentey
SSD: Sandisk SSD Plus 240GB
HDD: 2 x 2tb WD Red in RAID 1, 2tb Seagate Barracuda, 1tb WD Blue
The Pizza Cooker (server):
2x quad core 2.66 ghz Xeons
16gb DDR2 FBDIMM
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608191
I ran malwarebyets full system scan a few nights back nothing came up i can run it again. As far as windows goes being on upgraded windows 10 with out a disk how do i go about that ? Also im just double checking this ram usage is no where near corret right.
Write down your product key, download Windows 10, put it on a USB or use the installer.exe, then if the product key doesn't work use the contact support app and they'll give you a new one.
i like linux
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608193
Alright will do thanks for the help the product key is my product id right just wanna makre sure ive got the right one
No the product ID is different, you can find the key with this: http://www.nirsoft.net/utils/product_cd_key_viewer.html
i like linux
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608201
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608220
I only have 8GB of RAM, and at the desktop almost none of that is being used. I would say an antivirus or a multitude of other programs that run in the background could cause this, but with 16GB, it'd take some effort to download enough crap to use up all that. If you have an old copy of Windows (2 years old or older) then Windows is known to do this after a few years of using the same copy. I say buy a copy of Win10 and start fresh. That'll be a sure fix to that issue.
HP x360 14, Core Ultra 5, 16GB
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608224
Do you have the pagefile enabled? If its off, the OS has nowhere to dump unused memory and ram just fills up after a while.
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608225
I mean this windows was installed around september then upgraded to 10 soon after so its not super old it was win 7
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608229
I do not know what you mean can you give me more info so i can look into this
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608230
Make sure it doesnt say 0Mb
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608244
After a restart the ram usage goes down. I did reseat the ram, i have a feeling that it might be the killer memory leak so ill watch that and keep an eye on it for the next couple days thank you so much  for all the help guys
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608275
If you upgraded to Windows 10 then you won't need a key. It's held on Microsoft's servers and will be activated when you connect to the internet.
If you change your computer hardware then your Windows key will become invalid. Not all hardware, just the main components.
I had a Killer 2100 (old I know) and the software didn't work well with Windows 10 so I removed it for now I until I get time to mess with it.
You don't need a page file if you shut your computer down and have enough ram.
I don't use a page file and have not for years (Vista times). Never ran into a problem as I shut my computer down when I'm not using it.
It's not a race to the bottom.
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7608526
Delete/stop using that Chrome junk spyware.  Its obviously creating a memory leak and/or utilizing excess resources.
Seriously, look at how many Chrome processes are running.  That's the culprit.  Its pretty obvious.
IE11 and/or Edge work fine on my computer with only 4gb of RAM on Windows 10.
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7609141
Call Chrome a spyware and use IE/Edge. topkek.
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7609305
21 hours ago, ShadowTechXTS said:
1
So after all day of usage snice i restarte dalst night my ram usage is slowly climbing the unpaged pool is grwoing alot oes this mean i have a memory leak probably killer ethernet? omfVl.png
https://linustechtips.com/topic/582970-ram-at-almost-max-usage/#findComment-7612811
