hello I'm about to start up on my m-itx build and I was just seeing if anyone knows if one slim 240 would work cooling a 6700k and a gtx980 both a little overclocked or should I try and put two 240 in my case I'm using a nova by caselabs so I can fit more then one but I kind of don't want to have more then one rad I think it would look cleaner with just one thank you
https://linustechtips.com/topic/582588-need-help-rads/
If you are overclocking then I would be hesitant with a 30mm rad. Go with the thickest you can get that fits your taste and if you are not happy with the temps and noise then add a second 240. With the Nova you could put this slim up top with fans above to fit under the case bezel or window edge and the thick one at the front with the fans on the inside.
https://linustechtips.com/topic/582588-need-help-rads/#findComment-7604813
I've been struggling to keep my water temps down with 2 980's and 280mm+120mm rad space.  So yeah I'd definitely go with 2 240's if possible.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/582588-need-help-rads/#findComment-7608012
A single 240 would be sufficient, granted your temps are going to be high enough to the point where water cooling was pointless, but it would still work.  If adding another is an option I would definitely go that route.
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/582588-need-help-rads/#findComment-7608279
