will cpu bottleneck 780?
Go to solution Solved by amintha1992,
no you should be fine. this is a powerful CPU whether people like it or not.
Hello i am maybe going to buy a new graphics and ram and was wondering if my cpu will bottleneck it in any way.
I have a FX8350 (AMD)
i may be buying a EVGA SC gtx780.
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/
no.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/#findComment-788684
not to echo the others, but not at all! mark as solved so the topic can be closed!
AMD 8350 // 8 GB Corsair Ram // PNY 780 Ti // Asus 1080p Monitor // Antec 120mm AIO // CM Quickfire TK w/ Custom Caps  // RAT 5 mouse // Audio Technica m50x // Behringer 4-line + Line6 8-line Audio Interfaces
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/#findComment-788733
Relatively to Intel i5/i7, yes.
If Phenom II can bottleneck it, new AMD CPUs can as well since new AMD CPUs are 5-10% faster (and actually slower than Phenoms if you compare clock-to-clock and take new instruction sets out of equation).
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/#findComment-789111
nope, i plan to be upgrading my 7870 in a year or so to a gtx 880 or whatever the amd equiv is and im running a 2500k
Sir, 2500k is likely 25-50% faster per-thread than FX 83xx and that's all that matters for gaming.
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/#findComment-789112
good job we're not talking per thread performance then
We're talking about gaming, so we do talk about per thread performance.
https://linustechtips.com/topic/58240-will-cpu-bottleneck-780/#findComment-789256
