hey guys looking t o upgrade to the 980 ti when the new gpus launch making it cheaper  but wanna have enough juice
wanna beable to max games again after upgrading to 1440p from 1080p
current specs
coolermaster elite 130 mini itx case
asus h97i (can overclock with the bios update  from asus but i proberly wont bother)
i5 4690 (will try to upgrade to a 4970 (if i can find stock dont wanna buy a new motherboard to do sky lake and cpu isnt to bad just will take a hit when streaming to twitch)
16 gb 1600 ddr 3 gskil ram
240 gb ssd
rm 550 psu
gtx 970 g1 gaming
looking for one that will
a) fit
b) the cables are super long (like this one )
c) quiet
d) enough room to go a bit higher if needed ie get a overclockable cpu or
not fussed on brands rather not go overboard its only a mini itx so i wont be going sli and oncve i get a i7 and 980ti i doubt ill upgrade for atleast 2 -4 years
unfortunately only able to get whats avaiilable at my local stores
http://www.msy.com.au/sa/adelaide/24-power-supply
http://allneeds.com.au/shop/parts/power-supplies
https://linustechtips.com/topic/582097-psu-upgrade-for-mini-itx/
