Need a little help
Solved by max_headroom,
56 minutes ago, SoupyPancakes said:Ill be getting 1 of these psu's depending on the wattage I need http://www.amazon.com/dp/B00DGHKK7M/?tag=pcpapi-20. I was thinking of going with this exact gpu any thoughts I have decided the 970 is just to expensive.
http://www.evga.com/Products/Product.aspx?pn=04G-P4-1961-KR
Im not to familiar with the 390
I would shoot for higher than 500watts for the 390.
If your current PSU is 400watts then it'll run a 970 easily.
