Could someone PLEASE measure the length of the 980 ti Reference PCB?
I just realized I have 10.5 inches of room, and Nvidia say the reference card is 10.5 inches...
Could someone please measure one of theirs so I can know before I order it? I would love you forever!
Thanks so so much!
https://linustechtips.com/topic/581586-980-ti-reference-pcb-length/
2 minutes ago, kickasssloth said:
No, I just got a used EK Plexi Block I couldn't pass up. But I found my answer and It should just fit Thanks though!
If you're using a universal block make sure to have adequate vrm cooling as well. And also make sure to do thorough leak testing for a used block :)
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
Where could i possibly find this information!?
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-980-ti/specifications
GTX 980 TI Graphics Card Dimensions:
4.376 inches Height
10.5 inches Length
Dual-width Width
Motherboard: Asus X570-E
CPU: 3900x 4.3GHZ
Memory: G.skill Trident GTZR 3200mhz cl14
GPU: AMD RX 570
SSD1: Corsair MP510 1TB
SSD2: Samsung MX500 500GB
PSU: Corsair AX860i Platinum
