You have to plug in your monitor in your graphics card, not your motherboard.
I5 4470     -     Cooler Master Hyper 212 evo    -    Asus Strix GTX960    -    12Gb ram    -    Adata SP600 128Gb    -    Seagate 2Tb    -    AsRock Fatal1ty B85 Killer    -    Seasonic M12II EVO 520
IN WIN 703    -     Dell P2414H    -    LG Flatron M197WDP    -    CMSTORM Quickfire XT with MX blue's    -    Logitech  G502
Quote
"To finish first, you first have to finish"
https://linustechtips.com/topic/581364-vga-output/#findComment-7592165
1 minute ago, zehao39 said:
Is there any way I can use the motherboard as output?
no, but why would you?
Quote
https://linustechtips.com/topic/581364-vga-output/#findComment-7592180
ew vga, but I'm assuming the board only has onboard video wihout a card and when a card is detected or (hopefully this isnt a thing) a pci slot is taken it essentially cuts off the unneeded video ports. Try your bios if they have an option, or just stick with hdmi, dvi, or mdp to whatever.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/581364-vga-output/#findComment-7592188
