Help with choosing a case
Solved by SZ3r0,
Soupy you have a prebuilt PC worth around 300£ . You have a budget of 200...now i dont know if the are usd or gbp.
If i was you i will spend a little bit extra on the PSU and on the GPU. Let me give you some examples :
and for the case :
Jon im preety sure that he wanted to show us his computer. 540 case is specially designed for watercooling especially with rigid tubing. Spending around 100 gbp for that case is no reason for you . The spec 03 have a very nice look and also cable management (also someone here said that usually matx cases does not have enouf space...wich is tottally wrong)
