Computer not recognizing networking drive?!?!?
So my recent computer problems have shown me that I know nothing of how a computer works. Or at least not as much as I thought I did. In any case, my Dell laptop will only connect to the internet via an eathernet connector. It does not recognize my wireless connector. Does anyone know how to run a system diagnostics or whatever to see what the problem is? Thanks.
-LukeS
p.s. if you followed my other posts, here's an update: I got the SSD running Windows 8. I plan on upgrading to 10 asap, but I have to first install my basic programs (waterfox, Norton security, etc) and make sure all my drivers and such are installed (Wireless internet, all USB ports are working, etc). Thanks!
"I don't try to be smart, I try to observe. Millions saw the apple fall, only one asked "why?""
https://linustechtips.com/topic/581226-computer-not-recognizing-networking-drive/
If you plug it in and windows doesn't recognize it then try a different USB port.
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
Go to.
Control panel > Network and sharing center > change adapter settings
This should let you see all the adapters you have connected ensure the WiFi card is enabled .
There should be a drop down menu displayed on right clicking the adapter this gives yo an enable option as well as a connect/dissconnect option
on connesting there will be a little tick box for AUTOMATICALY CONNECT ensure this is ticked.
Hope this is any good for you and good luck.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
This is going to sound super retarded... BUT I decided that I was done with trying to fix the drivers and such... So I updated to msX (windows 10), and for some odd reason (idk why) it automatically fixed all my drivers including my internet. Sooooooo Yeah. Now I just got the long process of installing all my apps and programs. And hoping that I put all my school work on OneDrive (as my old hard drive is just a paper weight at this point). And trying to get my bookmarks back.
Hope this helps :P
It was the actual driver, not a thumb drive :P
Well this is awkward xD
