I'm using the tesoro excalibur spectrum
when i use it for some time , my right forearm becomes sore.
I checked my posture and keyboard position, and it seems fine
I think  that maybe its because my keyboard is relatively tall and my wrist has to bend upwards to type.
How do i solve this problem, would using a wrist rest help
(The spacebar is also too tall and straight for it to be very comfortable, but that is not the point)
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/
I have a Excalibur Spectrum too, and I have a memory gel wrist rest, it kinda helps, it kinda doesn't, the wrist rest itself is tall too so........
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589848
won't making the wrists on the same plane as the keyboard improve the ergonomics?
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589850
idk lel, with the rest it sometimes is comfortable, sometimes its not
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589859
3 minutes ago, BananaKnight said:
i got this keyboard a month ago, i already can't wait to get a new one
Well, the height is something I'm kinda alright with, its the Kailh switches that kills me. These fegits are not consistent throughout the board. What switches did you get yours in?
EDIT: And yes I'm getting another keyboard too, maybe a Vamilo VA87MR.
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589867
kailh blue, im pretty ok with the switch with one exception, the letter p. somehow only sometimes when i  press p, it gets stuck for a milisecond. But when i try to test it with another more sensitive finger the switch feels identical with the others. Bottomline is that i can't really feel the inconsistencies of the switches ( because this is my first mechanical keyboard).
I want something customizable , maybe something from WASD, and get them custom keycaps. But probably won't get it anytime soon.
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589877
Massdrop has a bunch of keyboard drops all the time, check it out there. Some of them have a lot of options to choose from. There are also keycap sets.
https://linustechtips.com/topic/581163-keyboard-ergonomics-help/#findComment-7589885
