Hey guys, I need some help choosing parts to build a pc. I'm looking to spend about $1500 usd. I'm really into corsair and nvidia parts so wherever those can be implemented would be great. Going to use it mostly for gaming, CS:GO and several others. Any help would be appreciated.
https://linustechtips.com/topic/580480-need-help-choosing-parts/
Welcome to the forum!
Why are you into NVidia parts in particular? Do you need to use CUDA cores Adobe applications like Premiere, or do you want to use Shadowplay to record your gameplay?
I can try to include them, but AMD also has great value options at this price range
Also, do you need a keyboard, mouse, and monitor? With $1500 to spend, you could play at 1440p or even 4k, which might require a display upgrade.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/580480-need-help-choosing-parts/#findComment-7583330
UPDATE: This is a repost. Please refer to his previous thread where you can find listed build recommendations from other users.
https://linustechtips.com/topic/580480-need-help-choosing-parts/#findComment-7583436
