GUYS PLEASE HELP.
I just recently build my first gaming rig, because i just read reviews and spec in the net i encountered a prob in my motherboard and chasis fan.
My motherboard only had two 4 pin fan connector. 1 for the cpu cooling and 1 for the chasis fan. but my chasis had 2 fan. i cant connect both of them on my motherboard.
is there a posibble way or splitter so i can connect both of them on my motherboard?
MOBO: Asus H110M-A D3
CHASIS: Corsair Carbide Spec-03
THANKS!!
https://linustechtips.com/topic/579922-please-help/
Also, you can use a 3-pin(on mobo) to Molex if that would be more convenient to you.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/579922-please-help/#findComment-7577908
