21 minutes ago, BobthePcBuilder said:
Hello,
So after you guys have selected your components and have them in front of you how do you go about building up the computer?(Also, How did you check that they were compatible and that they fit inside the case?) What tools do you use?
Thanks
Bob
Pcpartpicker is a great tool to check if your components are compatible.
Building the PC itself really is much easier than you might think. There are some nice tutorials on Youtube that cover basically everything you need to know about assembling a computer.
https://linustechtips.com/topic/579610-building-procedure/#findComment-7574959
