Hey guys! I hope I'm in the right topic here, but a friend of mine wants to build a wallmounted pc. What PCI-E extension cable does he need? He has a GTX960.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/579531-pci-e-extension-cable/
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/579531-pci-e-extension-cable/#findComment-7574152
He wants to have the something like this, but no watercooling. Sorry for low res pic :/
https://linustechtips.com/topic/579531-pci-e-extension-cable/#findComment-7574156
Up to 20 cm: cheap ribbon cable based once for 10$
> 20 cm: professional impedance matched riser from 3M: http://www.digikey.com/product-search/en?mpart=8KC3-0726-0500&vendor=19
They are expensive, but I have a 50 cm riser and it works perfect.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/579531-pci-e-extension-cable/#findComment-7574180
