Two GPUs with 2 monitors in the same system?
Su1tch
Hello, i have a question (couldn't find an answer on google), i have a dual monitor setup and i always watch netflix/youtube on the second screen while gaming and this cause a lot of FPS drops (i have a GTX 960) and i was wondering if i could install a second video card to minimize the load on the main card and connect the second monitor to a second card (a low end card or something similar), soo the second card takes the load of the videos wich are being played on the second monitor, is it possible?
You could try plugging the second monitor on the integrated graphics if you have that. Otherwise you could get a cheap gpu and it would work too.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
It might end up being that the CPU would bottleneck your system. but I doubt netflix will affect it that much, maybe a drop in FPS of 5 frames is what I would guess.
My computers as of 2017/03
My Old PC
Dell Vostro 260 $150 2010
CPU: i3-2120@3.3Ghz, GPU: Intel HD Graphics 2000, ATI Radeon X1300, RAM: 4GB Axevir Budget Series, SSD: 240GB Radeon R7, HDD: random 250GB and random 160 GB, CASE: Crap from Dell, OS: Windows 7 Enterprise
My Current PC
Custom Build $1200 2016
CPU: i5-6600k@3.6Ghz, GPU: Sapphire R9 Fury, RAM: 16GB Geil EVO X, SSD: 240GB Radeon R7, HDD: Hitachi 500GB, CASE: Deepcool Kendomen, OS: Windows 10 Professional 64-Bit
Laptop
ASUS F8S $1150 2008
CPU: Core 2 Duo T7500, GPU: ATI 2400 Mobility, RAM: 8GB Mushkins, SSHD: 1TB Seagate Hybrid Drive, OS: Windows 7 Ultimate N and Windows 10 Professional
HTPC
MSi Cubi $200 2016
CPU: Pentium 3805u@1.9Ghz, GPU: Intel HD, RAM: 4GB Crucial DDR3L, SSD: 120GB Radeon R7
Other Laptop
HP 2210b $400 2009
CPU: Core 2 Duo T8100@2.1Ghz, GPU: Intel GM965, RAM: 2GB Hynix, HDD: Hitachi 160GB, OS: Linux Mint 17.3 and Lubuntu
*All Prices in the Canadian Dollar
If you want to watch videos on a second monitor and you are having issues with it in your main gpu,  plug the monitor on your on board graphics.
I was thinking something along the lines of that myself. Since its not rendering 3D, it shouldn't be taxing the card that much at all. It could be ram or vram shortage too.
Yeah I would check your CPU usage while you're running Netflix and a game, because I can run a game on my main monitor and a stream on my second no problem with a GTX 760. If that is the problem then there's not a lot you can do without a CPU upgrade. If that's not the problem, then other stuff people have said here is pretty good advice.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
Thanks for the answers! i'll try to plug in the second monitor to the on-board video plug, but do i have to change anything in the settings? or it will pickit up automatically?
You might have to enable it in the bios. On my computer, it turns the integrated output off by default if I have a discrete graphics card plugged in.
