Wi-fi connection problems.
Go to solution Solved by Hackentosher,
I sometimes get this issue, I find that resetting my modem fixes the problem. If your modem is getting really warm, I think that contributes to the problem so make sure it has access to plenty if fresh air.
Hello.
I have a small problem.
Since a view weeks i got this really anoying problem where every once in a while all my devices at my home, (Phones, Computers, laptops,) witch are connected to the internet via Wi-fi, simply won't connect.
Most of the time it works commpletly normal. But sometimes all my devices pick up the signal and try to connect to the Wi-fi and just ,,don't,, It doesn't give out any error message. It simply won't connect. I called my Internet provider and they sent me a new router. ..twice.. I really don't know what's the problem because after a restart it usualy works again.
I would be insanely happy if anyone has some tips or trick's or if anyone experinenced the same problem.
Thanks in advance. Samuel
https://linustechtips.com/topic/578849-wi-fi-connection-problems/
