Idle Temps
Go to solution Solved by don_svetlio,
21 minutes ago, aviationjames said:
Yes, it does have 0db mode. Did not think it would turn the fans off at a high temp though. Its the MSI Twin Frozr
It turns the fans on after 65*C
I got an AMD R9 380 the other day, and my temps for Idle are pretty high compared to my old GTX 660.
This is after booting up windows:
Why is it so high?
I'm also only getting 25FPS on normal settings on GTA with most options turned off :(
Although I am running an i3 6100, but it was more than 25FPS on medium settings with the GTX 660.
https://linustechtips.com/topic/578002-idle-temps/
Why is it so high?
it is far within safe but it is quite high for idle, check if your card has a 0db or 0fan mode some cards shut down their fans completely at idle but then the temps will be higher
Gaming rig) i5-4690k@3,5ghz,4,1ghz turbo , gigabyte z97x-gaming 3, hyperx fury red 2x4gb(1600mhz), msi GTX 970 gaming 4, corsair cs650m PSU, corsair carbide spec-03 case, be quiet pure rock Cpu cooler, kingston v300 120gb ssd, samsung evo 830 120gb ssd, segate baracuda 1,5tb hdd, Laptop 1) HP pavilion power, i7 7700hq, 16gb ddr4, 256gb nvme ssd, 1tb hdd, nvdia gtx 1050 Laptop 2(linux mint)Dell Xps 15(2011), i3-2130m, nvidia gt525m, 4gb 1333mhz ram, 500gb hdd Laptop3(mint and windows)Dell inspiron 15z(2013), i5-3337u, hd 4000 graphics, 6gb 1600mhz ddr3, 500gb hdd, 32gb ssd(RST) First PC(still using for some windows XP programs)Amd athlon xp 1500+@1,96ghz, 2gb 300mhz ram, PNY geforce 6200, 80gb maxtor hdd, asus(tek) a7n8x-deluxe , 450W psu, spire case
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558538
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558542
i have a twinfrozer gtx 970 it starts the fans at 65c but if you are not comfortable you can make a custom profile in msi afterburner and set the treshhold to for example 40c why you are getting low fps i cant tell, try to see your cpu/gpu usage/temps while in game if your cpu is 100% and gpu lower you are bottlenecked by cpu. other if your gpu is 100% and still low fps there is something else wrong like to litle ram
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558550
Yeh, CPU says 97% on GTA V - just remembered lol. Either I am going to get an i5 6600K or i7 6700K. Not too sure which yet.
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558557
basicly the i5 would be enough for casual gaming but if you have the money i7 is better especialy if you are planing to render some video and stuff like that but for more cpu questions make a topic in the cpu thread
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558569
https://linustechtips.com/topic/578002-idle-temps/#findComment-7558606
