**FOR THE SAKE OF SIMPLICITY AND SHORTAGE OF TIME, THE POST IS ONLY DIRECTED TOWARDS THE GTX980 TIs**
So I thought I had everything figured out and I do (for the most part) except the GPU (which is the most part; ie I'm screwed)
So I decided I'd get a GTX980 TI from EVGA which was to cost me about 812$ (I'm in india so this is after converting Rs. 54,000).
Then I landed on the EVGA website and found a metric ton of more options in the GTX 980TI itself...
Then I researched and found out about reference models and custom models and decided to go with a custom model.
I have no clue of what I'm going to buy when I go to shop tomorrow and for some reasons, tomorrow is the only time I can go and everything is super expensive online.
Can you guys suggest some GTX 980TI cards from EVGA that are a little more but mostly the same range but custom.
EVGA was available that's why I'm stressing on EVGA. Are there other branded custom GPUs that I can buy? Since stock availability isn't sure, you can tell me more than one GPU(s) to look out for :)
IS A CUSTOM GPU WORTH IT ANYWAY?
https://linustechtips.com/topic/577824-help-me-choose-a-gpu-please/
EVGA FTW or EVGA SSC 980ti. Go with the SSC if you plan to do overclocking because you can just overclock to the FTW clock speed unless you want to go balls to the walls and get the Classified or Kingpin which tend to run for a lot more than the others.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
