Will this set CableMod E-Series G2 / P2 Cable Kit - Black/White be enough to connect everything in my setup to the motherboard?
Setup:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($357.52 @ Amazon)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($114.99 @ Amazon)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($7.82 @ Amazon)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($154.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.00 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($122.66 @ Amazon)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($370.73 @ Amazon)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($164.47 @ Amazon)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Software: Microsoft Office Home and Student 2016  ($115.90 @ Amazon)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($39.95 @ Amazon)
Case Fan: Aerocool DS 140mm White 93.4 CFM 140mm  Fan  ($21.99 @ Amazon)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  ($269.00 @ Amazon)
Keyboard: Corsair STRAFE RGB Wired Gaming Keyboard  ($149.99 @ Amazon)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($59.99 @ Amazon)
Headphones: Kingston HyperX Cloud II 7.1 Channel Headset  ($90.00 @ Amazon)
Total: $2564.95
Generated by PCPartPicker 2016-04-06 10:00 EDT-0400
CPU: Intel i7-6700k - GPU: EVGA GTX 1080 FTW - Motherboard: Asus Z170-A - RAM: Vengeance LPX DDR4 16GB 3000MHz - CPU Cooler: Corsair Hydro GTX H110i - PSU: EVGA SUPERNOVA 650W P2 - Case: NZXT H440 White/Black - OS: Windows 10 Home - Mouse: Logitech G502 - Keyboard: Corsair Strafe Cherry MX Red RGB
https://linustechtips.com/topic/577606-will-this-sleeved-cable-kit-work/
1 minute ago, kimsejin5 said:
You should be fine. The EVGA power supply and the CableMod sleeved kit are the only two that really matter for compatibility.
Yeah but the question was if all the cables in the kit were enough to connect everything so that I don't have to buy other cables.
You should be good. The only thing that I'm not sure about (and this is hard to vet the compatibility of) is the length of the cables in the case. The recommended cable length typically isn't stated on the manufacturer website, so while most of the time, it will fit, the 8-pin EPS connector SOMETIMES won't reach all the way (I had this happen with a Seasonic grey unit in a Corsair 100R)
"Not breaking it or making it worse is key."
"Bad choices make good stories."
That PSU is not on the cable compatibility list
https://cablemod.com/compatibility/
that is a GQ
the cables are only for G2 or P2 or T2
that is a GQ
I forgot to change the CPU on PCP . Thanks for reminding me :P
do you mean PSU?
CPU is a different thing :P
2 hours ago, Enderman said:
do you mean PSU?
Shit, I messed up the names :/
