mini ITX build?
13 minutes ago, alexdavidjohnny said:so the minus is just no SLI/crossfire and no overclocking right?
can you recommend me a cheap 1151 itx board?
thanks for the warm welcome
You can overclock. As long as you get a z170 board with a 8 pin CPU power connector. I would reccomend any H110 or H170 board with built in wifi (which is a common feature on mini itx. Maybe look at this Gigabyte (http://www.newegg.com/global/au/Product/Product.aspx?Item=N82E16813128871&cm_re=Gigabyte_h170_wifi-_-13-128-871-_-Product).
You will also lose ram upgradability in most cases. Most itx boards one with room for two ram sticks, the only exceptions are super high end ones. I would go for a single stick of 8gb so you can upgrade to 16gb in the future. Also cooler compatability. You will want a small cooler in most cases (ayyyy). I reccomend the Noctua Nhl9i or the stock cooler.
Do do you need recommendations for monitor, peripherals, sound or case?
Welcome me to the forums btw
