For some reason when i tried to export my adobe project the export windowed output keep showing "Rendering..." but it has been like this for more like 5mins usually before which is like a 3 weeks ago since i used adobe premiere pro it was working fine but when I try to render using "export" it will just get stuck on 0% for some old reason and this is same when i use media encoder as it will show it encoding but the progress get stuck on 0%. This is a bug or what?
Thanks in advance,
Magical Pineapples
https://linustechtips.com/topic/576872-adobe-premiere-pro-cs6-not-rendering/
Maybe try a clean install of the application.  Re-install it, although I know that's a bit off a b*tch to do.
// Floatplane Pilot //
Main Rig:  Motherboard: ASUS H270 - PLUS - CSM | RAM: Corsair Vengeance DDR4 16GB (2x8GB) | Case: Corsair Carbide Series SPEC - 02 | SSD: ADATA SU800 128GB HDD: WD 1TB Hard Drive | PSU: Corsair CX 550M | CPU: Intel Core i7-7700 Cooling: Cooler Master Hyper 212 EVO | GPU: ASUS GeForce GTX 1070 | Keyboard: Logitech G710+ Mechanical | Mouse: Razer Naga 2014 | Sound: Corsair VOID RGB / USB Headset | OS: Windows 10
Laptop:   Razer Blade Stealth 2016
Is there another options as im going to reinstall windows at end of the week...
Magical Pineapples
I'd say this is your best choice, but if you're going to do a clean install of Windows, that works too.  Just install it back when you're done re-installing Windows.
What's your specs?
By the way, your signature is such a troll... ;)
What's your specs?
My spec is high end, here you go: http://pcpartpicker.com/user/MrUnknownEMC/saved/#view=TPcwrH or you go down to end signature spoiler.
Magical Pineapples
Are you using DBAN on your HDD to wipe it completely, or just clean installing Windows on your SSD?
Well getting a new Samsung evo for my PC so im gonna do clean install on new SSD and use the old on for my laptop.
Magical Pineapples
