CPU very hot when benchmarking!
as themctipers put it, dont use 95. i let it go long ago. its practically like, 'ok, take my cpu to the limits of temperature where it gets hot enough to fry it' ![]()
AIDA64 is much better and controlled software IMO. u can benchmark same things, and even more, with more control and more reliability.
also, just a side note, check for hardware issues as well.
if i were you, i would first remove the rig out of casing, make it open, test it and then i would test again after assembling it inside the case. that way its much easier to may be remove and reconnect certain parts, if i find any problem.
also check for your cooler. check for fans connected, may be increase radiator speed a little. your room temperature effects SO much on your rig's temperature, trust me, im from a hot part of the world and i understand that people in colder areas get lower temps and vice versa.
