i have there green switches and they decent chroma blackwidow. i have the clicky ones .  the only problem i have with their keyboards some of them have derpy firmware pre installed .(i got one and didnt know that was a problem at first ) random key presses with no macros or buttons being pressed . but you just get the new firmware from them in a email which is quick and easy fix
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/575715-razers-switches/#findComment-7534495
40 minutes ago, FunctionCore said:
Is there any difference between razer's switches & cherry mx? Also, what is your opinion on razer's switches?
There switches are OK they are cherry clones that I think they shortened the travel on if I recall correctly that is. I'm not really a fan of the company that makes them because they were making cherry clones long before cherry lost its rights to the switch design.
https://linustechtips.com/topic/575715-razers-switches/#findComment-7534691
