Hi guys
I'm having an issue with my config in one of my systems and cannot find anything quite like what I am experiencing. Specs are as follows
AMD FX 8350
ASUS Crosshair V Formula-Z
16Gb Corsair Vengeance DDR3 1866 (4gbx4)
PowerColor AX7900 (the triple slot variant that came out before the the official one)
Various SSDS and HDDS
Coolermaster Silent Pro Gold 1000w
OS is Windows 10 Pro
On to the issue at hand. I use HDMI audio out, however, I see "AMD High Definition  Audio Device" listed twice. with one giving me a yellow triangle (so I disable it).   It doesn't cause me any problems, but I'd just like to know if any of you guys have any insight into what may be causing this issue. I know it's a dual gpu card, and likely has something to do with it, but the yellow triangle is what confuses me. If anyone else has a dual GPU AMD card and is running Windows 10, could you please look and see what it says on your side? Attached is screenshot. Any insight would be appreciated.
Kind Regards
Edited by r3d3mpt10n
typos
https://linustechtips.com/topic/575705-duplicate-amd-high-definition-audio-device/
  • 1 year later...
Hi guys
Looks like I am still getting this issue. It does not stop anything from working, I'm just curious about what it is that is causing it.  I am running the latest AMD drivers and Windows 10 Pro with all updates. Does anyone have any suggestions?
It would be greatly appreciated.
Thanks
